Old 05-01-2012, 06:43 AM   #1
Default Progressive Brake Upgrade for stock VW MK5 R32 & Golf R
This thread is extended from the summary topic of - Progressive Brake Upgrade - Discussing in detail for VW.
Old 05-01-2012, 07:45 AM   #2
Brick
Default Mk6 R calliper
Is the new calliper suitable to fit the OEM size rotor being 345x32mm? I note your drawing shows a rotor size of 345x30mm. What is the weight difference between the OEM calliper and your replacement calliper? Thanks
Brick is offline   Reply With Quote
Old 05-01-2012, 08:12 AM   #3
The stock size for MK5 R32 is 345x30 not 32mm. RB kit is designed and built for 100% bolt-on w/o requiring any sort of modification.
We will post the weight of RB460 caliper so you can compare with stock and Cayenne calipers (for Cayenne caliper kit contenders).
Old 05-01-2012, 08:37 AM   #4
Brick
Default Mk6 R
In Aust the mk6 R rotor size is 345x32mm. Not sure what size they have fitted to the US model.
Old 05-01-2012, 08:47 AM   #5
I see. We know MK4 is 330x32, MK5 is 345x30 so MK6 is probably 345x32 in the US also.
We have 345x32 rotor ring (same as for EVO 10), If MK6 indeed is 345x32 we can standardize the kit to 345x32. - The caliper is capable to fit up to 35mm thick rotor.
Since our rotor is center mount design so change of thickness will not change the offset like surface mount rotors will.
Old 05-01-2012, 09:04 AM   #6
nkgneto
For the following vehicles the 345x30 rotor is the same.
Make
Model /Submodel
Engine
Volkswagen
CC /4Motion
VR6
Volkswagen
Golf R /All
All
Volkswagen
Passat B6 /4 Motion
3.6L
Volkswagen
R32 MKV /All
All
Used ECS for reference
nkgneto is offline   Reply With Quote
Old 05-01-2012, 12:40 PM   #7
Your list of other applications are all for MK5, while it can be possible that MK6 uses 32mm.
I would account for OE part as the official guide than aftermarket's site, although in either size 30 or 32mm we shall have rotor rings.
Old 05-01-2012, 01:20 PM   #8
RB Caliper = 6.1 lbs
Cayenne Caliper= 9.0 lbs
RB caliper w/pads = 8.8 lbs
Cayenne caliper w/pads = 13.4 lbs
Total weight saving per caliper & pad = 4.6 lbs or 9.2 lbs per axle set over Cayenne kit
(RB caliper kit is 34% lighter than Cayenne caliper)
Old 05-01-2012, 02:40 PM   #9
nkgneto
Golf R is [MK6=6th generation (2012)]
Passat [B6=6th generation (05-11)] 4motion with a 3.6
VW CC [(2008-12) First Generation] 4 motion
R32 [MK5=5th generation (2008 only in the US)]
2012 Golf R
Technical Specifications
Power assisted, dual circuit, 13.6 x 1.2-in vented front
discs and 12.2 x 0.9-in vented rear discs
Old 05-01-2012, 06:52 PM   #10
Brick
Thanks for the update and glad to see your calliper will fit regardless.
I can confirm I have 345x32mm rotors as I have replaced them with Adams Rotors, as have quite a few dubbers from Aust. Perhaps different sizes for different markets.
Anyway, looks like the callipers will fit which is what I am after initially.
Old 05-01-2012, 06:54 PM   #11
nkgneto
Are your Adam's replacement thicker than stock?
Old 05-01-2012, 07:26 PM   #12
Default OE caliper and pad weight
Anyone has R32 can contribute to this so we can all share and compare.
Thanks
Old 05-02-2012, 12:33 AM   #13
Brick
nkgneto, you could be right.
I have been going back through info from when I did the rotor swap. Was told 345x32 was OEM size and which definitely is what I have put on, but not so sure now it was OEM size. Cannot find sizes through official Aust VW site.
Anyhow, I am just happy I can get a calliper to fit my current setup and will change to two piece rotors once I need to undertake a replacement.
Old 05-02-2012, 04:53 AM   #14
Brick
Guys, have had a bit of interest from fellow forum members in Australia. Any sort of timeline as to when pricing might be released.
Old 05-02-2012, 05:52 AM   #15
This kit will be tested on tracks in about two weeks before release.
Tentatively we schedule to release the kit for order in about 6 weeks with an estimated price of $1,480 for:
2 each of RB460 heavy duty calipers (powder coated to red)
2 each of caliper adapter (made of 7075-T6 high strength & light weight alloyed aluminum)
1 set of RB ET500 performance street pad
The above components can bolt on to MK5/6 spindle w/o any modification for an instant light weight high performance brake kit with visual appealing.
Optional
- two piece rotors
- stainless steel brake line
- blue color
- brake pad upgrade
Note for GTI and other non-R32, 18" wheel is required to fit the kit.
Old 05-02-2012, 06:28 AM   #16
Brick
10 out of 10 for prompt responses, thanks for the info.
Understand that pricing is only an estimate until design, etc is finalised. Needless to say I think you will see a good flow of orders from Aust starting with mine once they are good to go.
Old 05-02-2012, 01:03 PM   #17
Great White
Excellent news, can't wait for the release...
Great White is offline   Reply With Quote
Old 05-11-2012, 11:23 AM   #18
Brick
Out of interest, do the pads have the wear indicator?
Thanks
Old 05-24-2012, 08:20 AM   #19
The pad is a standard FMSI number and does not have wear sensor locator.
Old 05-24-2012, 10:14 AM   #20
OE caliper with RB two piece rotors:
After 7 track days RB rotors shows almost no wear (new is 30mm)
RB caliper loaded with new pads
RB caliper + Adapter
OE caliper with used pads
OE caliper + Bracket
Replacing complicated OE brake line to stainless flexible banjo line.
Nicely clears 18" wheel (aftermarket) even under weight balancer
(OE wheel would require 8mm spacer to clear the spokes
