Old 12-07-2017, 03:41 PM   #1
Default BMW M3/M4 CCB and Porsche PCCB Wheel Clearance Issue?
BMW
M Carbon Ceramic Brakes - Serious Wheel Clearance Issue (rocks / stones)
http://f80.bimmerpost.com/forums/sho...t=wheel+damage
Porsche
First Day on the Road Not So Good
https://rennlist.com/forums/991/1037...t-so-good.html
Replacement PCCB Calipers
https://rennlist.com/forums/991/1037...-calipers.html
Old 12-07-2017, 03:49 PM   #2
997 Caliper on Left; 991 Caliper on Right:
997 caliper has leveled body
997 Caliper Installed - Even surface & clearance across the wheel barrel
Due to this caliper has an even surface (ie even clearance) it will only "admit" (& pass the rock through), or "reject" the rock. In other words it's very unlikely to let the rock "roll" between the caliper and wheel barrel.
991 caliper has two-way tapered body
Height were measured from surface plate with digitized Coordination Measurement Machine (CMM)
991 Caliper Installed - Uneven clearance (Large on outboard, tight on inboard)
This tapered body will create an uneven clearance, once a rock is trapped (on lower side-wider clearance) it will roll towards inboard (high side-tight clearance) and get pinched between the caliper and wheel barrel causing damage.
Old 12-07-2017, 03:49 PM   #3
This set up has been running for more than one year w/o any issue.
RB 394mm CCM rotor kit fits under 19" Mercedes (CLS550) OE wheel
Wheel clearance
Check actual clearance (4mm) with a feeler gage
