Closed Thread
Old 03-22-2011, 10:02 PM   #1
Default Porsche Panamera Brake Upgrade
This thread is for Porsche brake upgrade options.
First we like to take a look on the Panamera. It comes with 6-piston caliper 390mm rotor, and 4-piston 350mm rear rotor.
What stock brake set up can be so massive than this set up? is there a room for improvement? - Just read on:
This company GMP Performance offers SpeedART Porsche packages:
racingbrake is offline
Old 03-26-2011, 11:16 AM   #2
Default Porsche 997 two piece rotors offered by Brembo
Brembo Front rotors (345x34): $1,895/pair
Brembo Rear rotors (350x28): $1,995/pair
Old 04-01-2011, 03:18 PM   #3
Girodisc two piece rotors for 996 upgrade:
http://www.6speedonline.com/forums/9...ng-rotors.html
Slotted Rotors: $2,400/4 rotors
Drilled & Slotted: $2,550/4 rotors
Rotors are 350mm for front and rear.
Old 04-01-2011, 03:39 PM   #4
Default Two piece rotors for 996 GT2, GT3 and 997 GT2, GT3, TT
BREMBO Type III Direct Replacement 2-Piece Front Floating Discs
NEW! for 996 GT2, GT3 and 997 GT2, GT3, Twin Turbo Porsche Models
February 26, 2009
Brembo Type III Direct Replacement 2-Piece Floating Disc Brembo has released an OEM replacement fully floating 2-Piece rotor for the stock Porsche braking system. When Porsche owners decide to take their vehicles to the limit on the street or track, improving the brake rotor can be one of the most substantial upgrades to the vehicle. These rotors were designed and engineered with racing in mind for Porsche owners who want the best performance for their vehicle!
*Highlights In The New Porsche Type III OEM Replacement Disc - Brembo Introduces: **
Type III Slotted Racing Disc *
350x34mm Wide Annulus 72-Vane Disc Front
350x28mm Wide Annulus 72-Vane Disc Rear
Sold As Full Disc Assemblies With Full Floating Anti-Rattle Hardware
Clear Hard Anodized Hat Color
Huge Weight Savings of 3 lbs per corner (22.6lbs Type III Disc, 25.5lbs Stock Disc)
Price Unit
229286 102.8006A Porsche 996 Turbo Front 350x34mm 2-Piece Replacement Rotors (PCCB Equipped): Fits 2002-2005 Porsche 996 Turbo $1,800.25 /Pair
229287 202.8004A Porsche 996 Turbo Rear 350x28mm 2-Piece Replacement Rotors (PCCB Equipped): Fits 2001-2005 $1,990.25 /Pair
Old 04-01-2011, 03:44 PM   #5
Default Two piece rotors for 996 and Turbo (01-04)
Brembo Porsche 996 911 C4S and Turbo (2001-2004) Brembo 2-Piece Performance Rotors
Part #: 101.6003A Excluding PCCB
High performance 330x34mm two-piece full-floating rotor assemblies for 996 C4S & Turbo to work with stock calipers and pads. $1,515.25 per pair
These are cross drilled and silver plated to match the stock rears but are lighter and perform much better than stock units. The hats are billet aluminum, just like the Gran Turismo Big Brake kits, and use the same McLaren Hardware System.
Old 04-02-2011, 08:37 AM   #6
nkgneto
Brembo 2pc Slotted 380x34mm Front Rotors PCCB Cars Porsche 997 Turbo 06-11 $2,107.19 per pair
These rotors are specific for the Porsche 997 Turbo. Because these rotors are PCCB replacements, you must also change the pad.
Brembo GT 2cp Slotted 350x28mm Rear Rotors for OEM Brakes Porsche 996 GT2/TT $2,011.19 per pair
Each rotor weighs only 16.9lbs compare to the stock rotor of 21.9lbs saving you 5lbs per corner.
nkgneto is offline
Old 04-04-2011, 10:22 PM   #7
Default GT3 PCCB - GTS Brake Swap
This thread at Rennlist discussing the replacement of PCCB rotors for GT3.
http://forums.rennlist.com/rennforum...ml#post8318700
Carbon Ceramic Rotor Option $8,000/axle
Replacement for 4 corners $16,000/4 rotors
Old 04-04-2011, 10:50 PM   #8
Default pccb-to-gt3-cup-steel-rotors-bitter-sweet-conversion
Rennlist:
http://forums.rennlist.com/rennforum...onversion.html
Old 04-08-2011, 12:47 PM   #9
Default 996 Turbo Brake Information
http://www.6speedonline.com/forums/9...h-fiction.html
Stock set up: 330x34 front; 330x28 rear.
Upgrade to 997 Turbo with 350x34 front; 350x28 rear
Front::
Coleman - The hats cost about $550 per pair and the rotor replacements are about $350 per pair plus hardware (12 rotor bolts each) and shipping. Total estd: $1,000 per pair
Rear:
If you won't care about retaining your emergency brake, you can swap your rear rotors to a two piece design as well, and plus them up. Otherwise your only plus sizing for the are the 997 Turbo rotor, and either using your 996 Caliper with a 12MM spacer and 997Turbo bolts, or going to the $1100 997Turbo calipers along with the 997Turbo rotor.
996 Two piece rotor upgrade FAQ
Old 04-11-2011, 08:33 AM   #10
Default S4 to GTS Brake Conversion Discussion
http://forums.rennlist.com/rennforum...otors-etc.html
Old 04-13-2011, 01:38 AM   #11
Default Upgrading to 997 Turbo Brakes for 996 Turbo / GT2
Upgrade from 996 to 997 turbo brakes
Disc Sizes:
996 and 997 brake disc sizes:
996TT/GT2
Front: 330X34
Rear: 330x28
997GT3/GT3 RS 10-11
Front: 380x34 (Incl. PCCB)
Rear: 350x28
All the rest
Front: 350x34
Rear: 350x28
The offset difference can be adjusted by the rotor hat if they are made from two piece rotors.
Old 04-17-2011, 03:30 AM   #12
Default Two piece slotted rotors
Two piece rotors offered by Vivid Racing
Old 04-17-2011, 03:33 AM   #13
Default PCCB to GT3 Cup steel rotors - bitter sweet conversion
6SpeedOnLine
http://www.6speedonline.com/forums/g...onversion.html
Old 04-17-2011, 04:56 AM   #15
Default 996 GT2 Front brake discs vs. turbo
What is the rotor difference between 996 GT2 and 996 Turbo
The gt2/3 rotor's hat is about 2mm more towards the wheel then the turbo ones.
turbo's disc will fit GT2 ( or GT3 ) hub with 1.5mm spacer between the disc and the hub.
So the 996 turbo rotor is 1.5-2mm shallower than 996 GT2
To be exact it's 1.7mm
Old 04-18-2011, 09:39 PM   #16
Default 996 Turbo Brake Information - DIY and Sorting truth from Fiction!
Front Brake Issues
GT2/3 Calipers - Direct bolt on
GT2/3 Rotors - NOT a direct bolt on
For rear axle:
Old 04-20-2011, 05:52 AM   #17
TRG Brake Parts for Porsche
http://store.trgparts.com/rotors--hats-c513.aspx
Old 04-24-2011, 10:41 PM   #18
Default 997S vs. GT3 Brakes
http://www.renntrack.com/forums/show...8834#post18834
Old 04-28-2011, 09:12 PM   #19
Default Racing Brake Technology
Follow this thread for the discussion of the latest development on brake technology at Renntrack.
http://www.renntrack.com/forums/show...9396#post19396
Old 05-13-2011, 10:53 AM   #20
Default Racing Brake Technology - A Discussion about the truth of components
4/23/11
Team, I've invited Warren Lin, from http://www.racingbrake.com/ to come over and have an online discussion with our community about brake technology and where he thinks the current trend is, some truths, some myths dispelled, and what he has to offer the Porsche community. He's known here as Warren-RB!
Warren and I have spoken on the phone, and emailed back and forth for pretty much the whole of this week, and we've shared our thoughts concerning what is being sold currently in the market. Over the next week I hope to have this internet exchange of info growing to multiple pages...
Let's please keep this discussion CIVIL and stick with the facts only. Please, lets throw out what we think we know about a specific product. This discussion will lead to topics like material composition and moletuclar structures, as well as jargain regularly used in selling you a part, and what it truly means...
Mike
Closed Thread
