Old 03-03-2011, 09:32 PM   #61
paNX2K&SE-R
Are these rotors still being sold? I can't find them in the catalog.
paNX2K&SE-R is offline   Reply With Quote
Old 03-03-2011, 09:45 PM   #62
See our complete offer for 240SX:
http://www.racingbrake.com/NISSAN_240SX_s/251.htm
Two piece rotors are on custom order only.
Old 03-03-2011, 09:56 PM   #63
paNX2K&SE-R
Wow thanks for the quick reply. I'm putting together an unconventional braking system for my '07 Forester XT sport (its basically a WRX underneath). I have adapter dogbones that allows the use of Z32 4/2 pot calipers. The rear setup uses factory Z32 rotors and I saw this thread when I did a search for 2 piece rotors. I'd be interested in a 2 piece Z32 spec rears with either a single 5x114.3 pattern or better yet a dual 5x100/5x114.3 (or single 5x100) pattern.
Old 08-09-2013, 03:14 PM   #64
This thread is reopened for developing the complete brake upgrade for 240SX.
Old 08-09-2013, 08:55 PM   #65
Default Rear Brake Conversion
Some 240SX owners asked about the rear BBK upgrade and our answer is due 240SX has no drum e-brake so if you upgrade to aluminum caliper BBK you will lose your e-brake.
Another alternative is to replace your rear hub spindle to 300ZX (w/rear drum e-brake), then it would be possible like this detail conversion write up here:
S13 300ZX Rear Brake Install & 5-Lug Swap
Parts-
Calipers $160 new pads included
Brake lines $90
Z32 Spindles $399 only needed dust shields so I sold the other stuff and recouped some money.
New bolts $10
Rotors $130
Old 08-12-2016, 04:28 PM   #66
Originally Posted by OptionZero View Post
Larger calipers from any Nissan Skyline GT-R also bolt up do the 240sx; 350Z front calipers require only enlarged holes on the spindle*.
Anyone here can confirm if Skyline rear spindle hub (all the same for R32/33/34) is the same as 240SX or 300ZX (both have 114mm caliper mounting spread); from above comment it looks like 240SX and Skyline have the same spindle
Front R32 spindle is available on eBay for purchase but we need to verify the rear spindle for R32/33/34 in order to adapting R35 (GTR) brake to R34.
350Z spindle uses M14 caliper mounting bolts vs. 240SX's M12 and both have 100mm mounting spread.
Old 09-09-2016, 05:31 AM   #67
nismoman240sx
It's similar to the 240sx and 300zx. The S13/S14 isn't actually EXACTLY the same as the Z32. The Z32 is made of aluminum vs. cast iron for the S13/S14. Also, the lower mount for the dampener is different between the Z32 and the S13/S14. That being said the R32/33/34 is very similar to the Z32 in that it's aluminum and has the same lower dampener mount. It is slightly different from the Z32 in that the toe rod connection is a ball joint type connection pressed into the hub, while the Z32/S13/S14 is a bushing type connection.
And since I've clarified all of that, when it comes to the brake mounting portion of the hub, they're all identical and can all interchange their braking systems.
nismoman240sx is offline   Reply With Quote
Old 09-09-2016, 07:58 AM   #68
Thank you for the clarification.
We are building a complete Carbon Ceramic brake kit for a R34, and it requires to make an adaptor to mount the caliper, so I think it's safer to purchase a rear spindle anyway to assure the fitment.
Old 10-09-2016, 06:47 AM   #69
nismoman240sx
I just purchased this kit for my 240sx. What size are the threads on the bleeders? I'd like to install some Speed Bleeders.
Old 10-30-2016, 02:36 PM   #70
nismoman240sx
I went to install this kit today and started on the rears. The adapter bracket doesn't clear the drum parking brake backing plate. I thought about just cut the backing plate down so that it would clear, but that would leave an opening for debris to enter the parking brake assy. A minor change to the design of the adapter would eliminate this issue. If you're interested, I can take pictures to show the clearance issue.
Old 10-31-2016, 10:17 AM   #71
Yes please send us a picture thanks.
Old 11-06-2016, 09:37 PM   #72
nismoman240sx
Rear brake adapter showing overlap;
Code:
Old 11-06-2016, 09:43 PM   #73
nismoman240sx
Click image for larger version
Old 11-06-2016, 10:05 PM   #74
nismoman240sx
I have also found multiple other fitment issues today when I tried to fit the rest of the system. I've already shown the adapter bracket issue. There was also a lot of overlap on the rear brake pad over onto the non-surfaced area of the rotor. On the front the brake lines aren't correct. There is a fitting in the middle of the line that attaches to the strut that isn't located in the correct position. Also, the bolts on the front brake adapter bracket are about 5/8" too long and stick way out past the bracket towards the rotor. I'll attach images of all of that as well.
Overlap
After I cut the backing plate so it would clear
Pad hanging over contact area on rear rotor
Bolts on front adapter bracket that are too long by 5/8"
Center connection point on front brake line in the wrong position. Stock style SS line that fits properly for comparison on the top of all the pictures.
Old 11-07-2016, 11:47 AM   #75
nismoman240sx
Oops! Stock line is on the BOTTOM of those pics.
Old 12-31-2017, 11:07 PM   #76
Default GTR brake retrofit for Skyline R34
Discussions:
In GTR Life:
R35 Brake Bracket
http://www.gtrlife.com/forums/topic/...brake-bracket/
Caliper adaptor kit (By JDM AutoLink GBP 1,050)
http://www.gtr.co.uk/forum/295913-jd...ml#post3710129
1) Front and Rear CNC machined 7075 grade aluminum caliper adapters
2) All required high tensile bolts and washers
3) Brake drum ring adapters for rear hand brake function (To be inserted into the bell housing)
4) Cone adapters for R34 fitment (14mm bolt holes). Not required for R32 and R33 fitment.
Offer by Supertechracing (GBP1,440):
http://supertecracing.com/product/su...version-kit-2/
Description
Supertec Racing R35 to Skyline GTR brake conversion kit. Made from high strength T7075 grade alloy complete with front and rear calipers brackets including high tensile bolt kit.
Also included in the kit is a complete new lightweight rear bell/hat solution saving approx 6lbs over stock bell and to allow use of the hand brake with the correct diameter for the Skyline GTR models.
Compatible with both early 380mm and late 390mm setups. Minimum wheel size is 18″ but this varies from model/manufacturer.
*Calipers, rotors, front bells/ hats and pads not included.
Old 12-31-2017, 11:14 PM   #77
Default Installation Discussions
R35 Brake Conversion-Supertec Kit
http://forums.gtrcanada.com/forum/sk...nversion/page1
Group buy discussion:
http://www.gtr.co.uk/forum/194649-r3...group-buy.html
Old 12-31-2017, 11:20 PM   #78
Front Adaptor:
Rear Adaptor:
Old 12-31-2017, 11:27 PM   #79
Front Kit:
Rear Kit:
