RacingBrake Header H1 Image
  spacer
 Home RacingBrake.com
General Information
    About Us
    Brake Technology
    F.A.Q.
    Feature Comparison
    Manufacturing
    Product Knowledge
Products
    Search by Category
Dealers
    Find a Dealer
    Become a Dealer
    Dealer Login
Media Center
    Gallery
    Magazines
    Testimonials
Forums
    General Discussion
    New Development
    Key Messages Posted
    Latest Topics
Support
    Careers
    Privacy Policy
    Tech Tips
    Warranty Information
  Payments
 Payments
Go Back   RacingBrake Forums > Category > New Development
Reply
Thread Tools Search this Thread Display Modes
Old 03-13-2017, 04:04 PM   #1
racingbrake
racingbrake's Avatar
Default Sintered brake pad for CCM rotors
After using OE pads with heat cycles - Surface pitting shown.
Two track events after using RB sintered pads.
racingbrake is offline   Reply With Quote
Old 03-14-2017, 07:31 AM   #2
racingbrake
Default
Sintered process is not a new technology but only some are used as brake pad for motorcycles, very few in car application, and none exists in high performance/CCM brakes.
Sometime it s/b easier for general readers to call it as a "Full" metallic brake pad vs."Semi-metallic" pad that is commonly known and widely used.
Making sintered pad is far more difficult and taking much longer time to make than traditional semi-metallic, as it's 100% metallic powder with more than a dozen of ingredients that's molded together via high heat and pressure, no resin nor additive like semi-metallic which certain metallic ingredient are bonded together by resin and the resin (of plastic nature) can only resist to certain temperature, when over the threshold temperature, the resin will melt and the metallic powder can no longer be bonded together so the pad will accelerate its wear, and emit the resin (commonly known as deposit) to the disc surface which can cause all kind of brake issue - vibration, loss of braking power etc.
Old 04-11-2017, 03:00 PM   #3
racingbrake
Default
http://www.gtrheritage.com/topic/671...cmcarbon-pads/
Before and after sintered brake pad transfer on worn out carbon ceramic rotor.
Old 05-14-2017, 07:19 AM   #4
racingbrake
Default How to restore your damaged CCM rotors at no cost
https://rennlist.com/forums/991-gt3-...t-no-cost.html
The friction couple (pad and rotor) compatibility is very important in the performance of all brake systems, not only carbon ceramic. However since CCM rotors generate much more heat than conventional iron (due to its lighter weight), so it's even more crucial in carbon ceramic application.
To achieve a healthy braking operation it's necessary to transfer a layer from the pad surface on to the rotor face. For iron rotors (with semi-metallic pads) this usually can be achieved with careful selection of iron rotor material and brake pad compound.
However since the CCM rotors brake is running at a higher (~30%) temperature level than iron so using conventional semi-metallic pad becomes challenging due to the temperature limit of resin that holds the friction ingredient together. Resin is of plastic nature so when the pad is heated up it becomes soft and starts losing its binding strength, that's when you feel brake fade and notice resin emitted to rotor surface with uneven/un-uniform layers (bad deposit) that will cause vibration and other ill effect.
Sintered pad on the other hand, uses no resin, and is of full (100%) metallic, it's composed of various metallic powder. Those powder were compressed together under extremely high pressure, under very high temperature, takes days to cure and form together with the steel backing plate which is made of high tensile strength alloy steel so they for more resistant to deformation (warping) under repeated heat cycles.
During bed-in process the sintered pad starts transferring a very "uniform" layers (good deposit) over to rotor surface which also forming a protective coat on rotor surface, from thereon the friction is taken place between the transferred layers between the pad and rotor surface.
If a CCM rotor is already damaged (pitted-rough surface) due to the heat stress & incompatible pads, after bedding in with sintered pad, those surface will begin to heal, and eventually the metallic layer will smooth out the entire disc surface, we used dial gauge to check run out on those healed surface and the run out is within the tolerance of .00013"
During this rotor surface healing (patching) process you will notice the pad will wear out faster than normal, but after the rotor surface is restored not only the rotor life is to be prolonged, but the pad wear rate will become normal.
Old 05-14-2017, 07:49 AM   #5
racingbrake
Default Difference of friction methos between Iron and CCM
The method of friction between ceramic discs and pads work differently than iron discs.
With iron discs it is the friction between the disc surface and the pad surface that provides the braking force, but with ceramic discs it is the friction between the pad material that has been laid onto the disc surface and the pad itself that is what provides the braking force.
After properly break in, what you would expect to see on the surface of the rotor is a nice uniform, reflective layer, which signifies the transfer of material from the pad onto the rotor*. If the transfer layer is patchy or streaky then this would indicate that the pad is operating out of its temperature window. Pitting on the surface is the initial signs of disc wear, where the carbon in the disc is oxidizing.
CCM rotor surface is as hard as a diamond, so no brake pad can ever wear the rotor down. The only possible cause that can damage the rotor is from over-heat that causes carbon to oxide and lose its weight, rotor surface becomes pitted which will wear the brake pad down like a sharp grinder. This is the point when the rotor require replacement or re-furbishsing.
OE requires rotor weight check with instrument and complicated process, so to help user better understand we have published an article - "How to determine when to replace CCM rotor ring"
http://forums.racingbrake.com/showth...t=rotor+weight
However we suggest "rotor surface check" is an easy and more practical way to check the healthiness of CCM rotors - If your brakes performs well, rotor surface looks good, and brake pad wear is normal then you should not be worrying about the weight.
*Transfer of layer from the brake pad to CCM rotor is a fusion process which can only take place with a right sintered compound under a high temperature that only CCM rotors can generate (not iron rotors)
Old 05-14-2017, 07:54 AM   #6
racingbrake
Default
Some conversations re weight checking:
Quote:
Originally Posted by CAOZKAN View Post
I wanted to update you about my situation. Even after my markers were almost completely gone and we assumed that the rotors needed to change, I went on a trip for 6000km. During this trip I was very stressed about the rotors and everytime I pressed the brakes there was a weird sound and vibrations.
I wrote and complain about rotors to BMW HQ, and Turkey dealer called me and they took the car for inspection. After one week, today I received a call from them, they are saying that they weighed all the rotors and they all had an average around 7.4kg vs min. 7.1kg ; therefore they concluded that there was no necessity for the rotors to be changed.
One side of me is really happy about the fact that even after the markers are gone, there is plenty of rotors left. On the other hand, if this is the case, how in future I will be able to understand the conditions of the rotors and why this sound and vibrations were happening. I really appreciate any comments/guesses about this issue.
Quote:
Originally Posted by racingbrake View Post
Here is RB's comprehensive write up on CCM rotor replacement:
http://forums.racingbrake.com/showth...hlight=replace
Note all presentation are based on published and imprinted numbers w/o subject opinion.
Nonetheless my recommendation to those who run CCM brakes is to use "visual" inspection to the rotor (surface) conditions than those "weight" or "wearing mark" suggestion, because all the braking debris build up in the drill holes do add up to the rotor weight* which can give false signal.
The weight or wearing mark suggested by the CCB rotor mfgr are something quantitative for a consumer to reference and observe, how you "feel" is still more important. I have seen people replace their CCM rotors due to ill operation, but hardly seen anyone replaces their rotors due to below minimum weight.
*Unless you clean up all the holes (clean with a pin and compressed air) after track days which I know only very few track racers doing this to keep their CCM rotor in shape. If you don't this regularly, over the time those accumulated debris becomes as hard as iron bits and block the holes, and can no longer be removed.
Old 05-19-2017, 08:13 AM   #7
racingbrake
Default Russ' RB CCM Kit set up
http://www.camaro5.com/forums/showpo...87&postcount=1
OE set up
OE caliper after running RB sintered pad
RB caliper and sintered pad installed
Front set up
Rear set up
Real Brake for the Real People.
Old 05-19-2017, 03:46 PM   #8
racingbrake
Default
ZR1/Z28 pads (front and rear) are the standard tooling for our sintered pads.
We are able to confirm that the front ZR1 pad can be modified to fit 991 GT3 OE calipers (yellow or red) as illustrated below.
Original ZR1/Z28 Front Pad (D1395)
Modified to 991 GT3 pccb Pad (D1768)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
View Forum Archive.
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
  TPM Products Inc. Copyright 1985 - 2009 TPM Products, Inc. TPM® and RacingBrake are our trademarks.
1556 Kimberly Avenue, Fullerton, CA 92831, Phone: 714-871-6392 Fax: 714-871-9736
