RacingBrake Header H1 Image
  spacer
 Home RacingBrake.com
General Information
    About Us
    Brake Technology
    F.A.Q.
    Feature Comparison
    Manufacturing
    Product Knowledge
Products
    Search by Category
Dealers
    Find a Dealer
    Become a Dealer
    Dealer Login
Media Center
    Gallery
    Magazines
    Testimonials
Forums
    General Discussion
    New Development
    Key Messages Posted
    Latest Topics
Support
    Careers
    Privacy Policy
    Tech Tips
    Warranty Information
  Payments
 Payments
Go Back   RacingBrake Forums > Category > New Development
Reply
Thread Tools Search this Thread Display Modes
Old 03-13-2016, 04:31 PM   #1
racingbrake
racingbrake's Avatar
Default RB-CCB Kit for Porsche 997 & 991 Non GT3 (142/130)
RacingBrake is pleased to present this CCM brake package with the following feature:
Package# RCCB-POR-02
CCM Discs: Made by Brembo and supplied by GM for the CCM brakes as the latest Corvette C7 ZR1 & Camaro Z28
Front: 394x36mm
Rear: 390x32mm
Calipers: Designed and made by RacingBrake
Front: 6 pistons (Track duty)
Rear: 4 pistons (Track duty)
Rotor Hats and Hardware:
Exclusively designed and tooled by RB for CCM rotor assembly to assure the rotor integrity with consistent brake torque delivery under extreme braking conditions, easy to assemble/disassemble.
Brake Pads: Same as ZR1/Z28 (for CCM application)
Front: D1395
Rear: D1165
Three levels of compound available: RB XT910 for performance street, OE ZR1 pad for street and medium tracking, RB sintered pads for dedicated tracking.
Benefit of RB CCM Kit.
  • Affordable pricing.
  • Excellent option to replace your old pccb or upgrade from standard iron brake.
  • Transform pccb to the latest CCM set up as Corvette ZR1 and Camaro S28 for the flexibility of disc and pad swap.
  • Low replacement cost on consumables (discs and pads), you can just purchase from GM dealers or online stores (Amazon or eBay) direct for cheaper price with more compound choice from other aftermarket.
  • Kit is built for DIY installation - Including SS brake exclusively developed by RB that eliminates OE rigid lines, brake pads also come with wear sensor connector.
  • Easy on going maintenance - RB's open top calipers allow you to change the pad w/o having to detach the caliper. Brake fluid change and bleeding will also save you frustration on our flexible lines.
  • Receive professional advice and service from RB*, before and after your purchase including our stock on CCM discs and pads for emergency replacement.
*We have been building similar CCM brake kits for GT-R, Mercedes GT-S, Camaro ZL1, Corvette ZR1 (Upgrade light weight hats) and Audi R8/RS5 etc. Under development are Porsche's, Ferrari F430 Scud. and Viper G5.
racingbrake is offline   Reply With Quote
Old 03-19-2016, 02:27 PM   #2
racingbrake
Default
In general this kit will fit those models come with the following caliper mounting spread. Typically 997TT and GT4
Front: 142mm (S106)
Rear: 130mm (S60)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
View Forum Archive.
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
  TPM Products Inc. Copyright 1985 - 2009 TPM Products, Inc. TPM® and RacingBrake are our trademarks.
1556 Kimberly Avenue, Fullerton, CA 92831, Phone: 714-871-6392 Fax: 714-871-9736
