Old 09-30-2005, 10:17 PM   #1
Default Two-piece Rear Rotors for Evo & STi
Do you make rear 2 piece rotors for an evo ?
Old 10-03-2005, 07:00 AM   #2
Yes, we will offer two-piece (with real drum brake made of cast iron like stock, not alumimum) for rear.
There will be two sizes:
- 13" (332mm) oversize (4 piston caliper) to go with our 14" (355mm) two-piece front (6 piston caliper)
- Stock replacement 11.8" (300mm) to go with our two-piece front stock replacement 12.6" (320mm)
Available in 2-3 month. Please check our website for products update.
Old 10-03-2005, 07:05 AM   #3
evo442
Out of curiosity, why not an aluminum hat like the front 2 piece rotors? Would be nice to have all 4 rotors match...
Old 10-03-2005, 08:49 AM   #4
Very good question.
There are two types of emergency braking, when you pull the emergency brake lever:
1. The rear caliper activates. This is a less expensive way to provide by motor company as all it needs is a linkage.
2. Rear drum brake in which the rotor is for normal braking by caliper, but also is a drum brake for emergency and parking, the drum brake is a separate mechanism from the caliper. So this type of setup is a combination of brake caliper and brake drum as the rear brake is a much safer set up than just caliper (emergency) brake, which can be seen more on true high performance import cars like EVO or Subaru WRX and STi.
See a typical design of rear rotor without drum brake Vs. EVO and Sti rear drum brake. (see the difference of deep diameter for drum):
Our design philosophy is safety first. In other words, we will not alter the material for its intended performance nature i.e. we use only cast iron for drum brake like OE, not aluminum. Although aluminum is easier to be made available but is not the right material for braking surface. We either do it right (even costs a lot more and harder to make) or don't do it. See our answer to STi forum for the similar concern.
http://www.iwsti.com/forums/showthre...t=30353&page=8
Old 10-05-2005, 08:56 PM   #5
evo442
Excellent answer. thank you.
The ebrake on my Evo proved to be very useful after a brake line blew with me going over 100mph down the back straight at a local track..
Similar Threads
Thread Thread Starter Forum Replies Last Post
RX8 Rear Two-piece rotor racingbrake New Development 21 03-29-2006 03:17 PM
