McLaren MP4-12C Carbon Ceramic Rotor Replacement
  • McLaren MP4-12C Carbon Ceramic Rotor Replacement
    According to official specifications at a glance:
    http://www.mclarenautomotive.com/uk/.../techspec.aspx
    Brakes Cast iron discs with forged aluminum hubs
    Brake Size (F / R) 370mm / 350mm
    Brake Calipers (F / R) 4piston / 4piston
    Optional Brakes Carbon Ceramic disc
    Optional Brake Size (F / R) 394mm / 380mm
    Optional Brake Calipers (F / R) 6piston / 4piston
    McLaren Optional Carbon Ceramics vs Standard Cast Iron brakes
    Conversion Note:
    Front Brakes: The Carbon Ceramic brake system utilizes the heftier 6 pot calipers, larger pads and the carbon air duct. Please note that the weight of the front 4 calipers in the picture taken includes the steel braided brake lines, bolt, caliper pins x 2 and pad spring (hidden from sight). This results about approximately 0.6kg (1.32lb) of weight savings per corner.
    Rear Brakes: Both options utilizes the 4 pot calipers, so only the rotors differ. Other visible hardware changes include a new slightly larger bracket for the rear parking brake and the carbon air duct. This results approximately 2.2kg (4.84lbs) of weight savings per corner.
    Standard Brakes (Iron rotor replacement):
    Front 370x32 (Ours 370x34); Rear 350x32
    CCB Brakes (Converting to iron rotors)
    Front 396x34 (Ours 394x36); Rear 380x34 (Ours 380x32)
    Our brake design is 2mm thicker on the front rotors, and 32mm for the rear.
    Stock wheels 19" 8.5J Front; 20"x11J Rear
    Pads for 570S/650S w/Carbon Ceramic Brakes
    Front is the same as Corvette ZR1/Ferrari F458 front (PD1395), available from RB with sintered compound.
    https://racingbrake.com/-pd1395-360
    Rear appears to be DR42 (8597) and also very similar to our PD1149 with 141.6 with and 76.6 height, which sintered compound can be made available.
    • #3
      See our complete brake offer for McLaren.
      https://racingbrake.com/mclaren-2/
      • #4
        Complete brake system replacement is up for ordering.
        https://racingbrake.com/RCCB-MC-01
        Click image for larger version
        • #5
          Carbon ceramic rotors for McLaren 570S and Mp4-12C are available for ordering.
