Two piece rotor for BRZ Ts
  • Two piece rotor for BRZ Ts
    2020 Subaru BRZ Specifications
    Brakes
    Disc - Front (Yes or ) Yes
    Rear Drum Diam x Width (in) NA
    Brake Type 4-Wheel Disc
    Rear Brake Rotor Diam x Thickness (in) 11.4 (290mm)
    Disc - Rear (Yes or ) Yes
    Brake ABS System 4-Wheel
    Drum - Rear (Yes or ) NA
    Front Brake Rotor Diam x Thickness (in) 11.6 (294mm)
    Run some check on the OE specs and they appear the same as the WRX in front and Legacy in the rear
    Front: 294x24mm
    Rear: 290x18mm (Ventilated); 290x10mm (If non-ventilated.)
