Adjustments to current kits?
  • Adjustments to current kits?
    You have the 12" kit for the ND Miata which is incredibly close to my desired application but not quite right. The end-point is a non-sport brake RX-8 setup, which would need the 5 lug hat for the NC/RX-8, and a different adapter likely for the NC type mounting, though admittedly it's possible the ND and NC upright has the same mounting bracket dimensions i would guess not. Thoughts on swapping those hardware for the ND Kits as a possibility? Then I could work with a machine shop to see if i can get the mounting bracket just right.
    We are very familiar with RX8 (=Miata NC) and Miata ND - Two entirely different spindles:
