Bedding-In Instruction for new CCM brake pads & discs
Care Point: New pads and discs must be bedded in otherwise the overall brake performance will be degraded and use light brake applications if possible whilst driving to the location.
Bedding new brake pads/discs - Carbon Ceramic Material (CCM)
Step 1:
Care Point: The cool-down periods are the minimum needed and can be longer.
Step 1:
- Slow the vehicle 10 times from 80 km/h (50 mph) to 30 km/h (19 mph) at ~0.3g
- The disc temperature should be between 100-300 C the cycle time is around 10 seconds (between brake applications)
- Drive 3 km (2 miles) to allow the brakes to cool.
- Slow the vehicle 10 times from 120 km/h (75 mph) to 30 km/h (19 mph) at ~0.5g
- The disc temperature should be between 100-500 C the cycle time is around 15 seconds (between brake applications)
- Slow the vehicle 10 times from 140 km/h (88 mph) to 30 km/h (19 mph) at ~0.7g
- The disc temperature should be between 100-700 C the cycle time is around 20 seconds (between brake applications).
- Drive 4 km (2.5 miles) to allow the brakes to cool.
