This article is re-published from Optimising carbon-ceramic brake disc design for same-size replacement of cast iron discs.
http://www.surfacetransforms.com/fil...march_2014.pdf
Written by Greg Harris, Sales Director - Surface Transforms
%20Brake%20Disc%20Assembly.jpg)
Image 1 – Carbon-Ceramic (CSiC) Brake Disc Assembly
Introduction
Due to its reduced weight (typically 50%) and increased durability, carbon-reinforced silicon carbide (CSiC) ceramic composite offers a best-in-class alternative to traditional iron or cast iron brakes. However, the application of CSiC brake discs has remained the preserve of the mainstream high-performance OEM market, primarily due to the high unit cost but also due to the re-engineering normally associated with employing CSiC brakes. This is because ceramic composite brake discs generally need to be of a larger diameter to provide comparable performance to a cast iron brake system. This requires significant re-engineering of the brake components, wheels and related areas to accommodate the larger brake disc. This has limited the adoption of CSiC brakes for small volume or niche applications as these engineering costs, combined with the high tooling costs for any new design, make the technology unattractive.
Scope
This project aimed to simplify the re-engineering process in moving from cast iron to CSiC discs by replacing the cast iron brake
discs with CSiC brake discs of the same dimensions. To account for differences in specific heat capacity and density a larger CSiC disc is generally required to replace an iron disc to achieve a similar thermal mass and hence similar performance. The material properties of the continuous fibre construction allow a disc of the same dimensions to have comparable thermal performance, providing the potential to replace a cast iron disc on a like-for-like basis.
The project therefore focused on CSiC brake discs made with continuous fibre construction.
The project was part-funded by the Niche Vehicle Network and was undertaken in conjunction with Briggs Automotive Company (BAC) Ltd. The project aimed to improve the standard braking system on their supercar, the BAC Mono.
Image 2 – The BAC Mono Supercar
The target was to maintain the existing hub, caliper and other brake components, to keep costs down and minimise re-engineering. A secondary aim was to reduce the weight of the brake disc even further and investigating the impact on performance of increased diameter
cooling vents.
Chopped Fibre vs. Continuous Fibre
Chopped-Fibre is the standard material used in the construction of the CSiC d iscs found on many high performance vehicles, such as Ferrari, Porsche and Aston Martin. This material consists of carbon-fibre cut into short strands and mixed with a resin.
Continuous fibre material is made from layers of Poly-Acrylic Nitrile (PAN) cloth, a carbon-fibre pre-cursor, that are laid over each other (typically in a 0°/90° layup) and needled together to produce a matrix structure. The final product generated by each process are similar, however the Continuous Fibre material benefits from higher strength and significantly higher thermal conductivity.
The thermal conductivity of ST's high conductivity material is typically 3 times that of the chopped fibre material. The manufacturing process of continuous fibre is also more suited to small volume or niche vehicle applications as the parts are machined as opposed to Chopped Fibre discs that are moulded. This results in minimal tooling costs and greater flexibility in production.[/B]
